CNC router build - Page 23
Page 23 of 24 FirstFirst ... 132021222324 LastLast
Results 441 to 460 of 466
Thread: CNC router build
  1. #441
    ericks
    Guest
    Default Re: CNC router build
    Well...i was going to make my own vacuum table but like always too busy with other stuff. So my wife said ....honey just buy one, so i did. Shipping from Germany is just crazy expensive though. Hope it works well for the price i paid!! It's just the table so i still need to sort the valves and vacuum pump...
  2. #442
    ericks
    Guest
    I thought i would give a little feedback on the machine, now that i have been using it a lot. First the spindle motor is working great, the Sako drive is also performing very well. The machine itself is better than i ever expected....i still have to complete some work on the cabling and control panel. Reason for this delay is i am still deciding on e few things. The Aussie made bob is excellent....this is my choice from now on.
    CNC router build-wclock-jpgCNC router build-img20190525135856-2-jpgCNC router build-lights1-jpgCNC router build-lights-jpgCNC router build-horse1-jpgCNC router build-panelx-jpg
    Attached Thumbnails Attached Thumbnails CNC router build-panelx-jpg   CNC router build-wclock-jpg   CNC router build-img20190525135856-2-jpg   CNC router build-lights1-jpg
    CNC router build-lights-jpg   CNC router build-horse1-jpg
  3. #443
    ericks
    Guest
    My first ever youtube video...only to see how it would look/work
  4. #444
    Sep 2005
    Nice work and nice job on the wiring.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  5. #445
    ericks
    Guest
    Thank you
  6. #446
    ericks
    Guest
    Looking at that unfinished/messy control panel it's now about time i finish all the wiring and tidy it up!
  7. #447
    ericks
    Guest
    Managed to tidy up the panel a bit. Hope to complete everything soon
    CNC router build-panely-jpg
    Attached Thumbnails Attached Thumbnails CNC router build-panely-jpg
  8. #448
    ericks
    Guest
    Made use of some bits of acrylic lying around and made the first terminal box for the x-axis stepper motor. Hope to do the other motors soon...
    CNC router build-tbox1-jpg
    Attached Thumbnails Attached Thumbnails CNC router build-tbox1-jpg
  9. #449
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    How is it attached to the motor? Did you drill and tap the back plate?
    UCCNC 2017 Screenset
  10. #450
    Member davida1234's Avatar
    Oct 2009
    I guess high temp double sided tape?
  11. #451
    Member handlewanker's Avatar
    Sep 2006
    Hi, you'll need a 3D printer to make those parts...….there's no end to the fun you can have.....it opens up a complete new World...….I've just been bitten by the plastic bullet so nothing is going to get done now.
    Ian.
  12. #452
    ericks
    Guest
    Quote Originally Posted by ger21 View Post
    I used the existing two tapped holes, they had a tiny plastic bit holding the cable in place
  13. #453
    ericks
    Guest
    Quote Originally Posted by handlewanker View Post
    Ian.
    Hi...rather not, i don't have time to get into that too
  14. #454
    ericks
    Guest
    A better view of the inside of the boxes...
    CNC router build-tbox20-jpg
    Attached Thumbnails Attached Thumbnails CNC router build-tbox20-jpg
  15. #455
    ericks
    Guest
    Next step in the build will be to install brackets for the limits. For now i will add brackets but for version 2 of this machine it will be incorporated in the machine brackets. I have now had two guys asking me for a quote to build them a similar machine. Obviously they will get a neater and improved design....quoting and time to build is the challenge, my plan was to only build control panels for now due to time restraints
  16. #456
    Member ericks's Avatar
    Sep 2019
    Decided to mount the vacuum table today. Hope to have it sorted this week
    Attached Thumbnails Attached Thumbnails CNC router build-vacuumtable1-jpg
  17. #457
    Feb 2005
    Nice work!
    Did you build that vacuum table or buy it? If bought where at and aproximatly how much?
  18. #458
    Sep 2019
    Quote Originally Posted by nlancaster View Post
    Nice work!
    Thanks, i bought it from a supplier in Germany. I will have to check how much and from who i ordered it. I do remember shipping was crazy expensive
  19. #459
    Sep 2019
    The company is called cnc-plus....i honestly cant remember what i paid, it was a while back
  20. #460
    Sep 2006
    Hi, what are you using for the vacuum part? …...I just "found" a vacuum cleaner, sans the suction hose, on a nature strip and it still runs.
    It's a Piranha Phantom model, 2,400 Watts and sucks like crazy.
    The vaccy is so quiet it's almost silent at 3 metres distance.
    They retail at about A$124.00 on EBAY.
    Ian.
CNC router build
CNC router build
