Need Help! Air blower for cutting
Results 1 to 14 of 14
Thread: Air blower for cutting
    Apr 2013
    canada
    Default Air blower for cutting
    I am looking for options to blow air onto the material and cutting bit of my machine. The air is needed to remove the cut material as well as keep the bit cool as the tend to heat up and break. At the moment I am using an air nozzle connected to my air compressor. This is working great, but I would like to look at options to remove the compressor and have a dedicated blower just for the machine. I have attached pictures of the nozzle that I am using well I was cutting some material. I would like to keep using the same nozzle but I need a new source for the air. I have also attached another picture of an air pond pump and was wondering if something like this would provide enough air to do the job. My current setup only requires 10psi of air and is blowing through a 1/16th size hole. Any suggestions would be great and if you can provide a link to where I could purchase and suggestions, that would be a big help.
    Attached Thumbnails Attached Thumbnails Air blower for cutting-image2-jpg   Air blower for cutting-image1-png
    Apr 2004
    Default Re: Air blower for cutting
    If that's what you need, yes the little pump should work. This is very similar to a lasers air assist and they use pumps like that.
    Jun 2012
    Quote Originally Posted by cncmadness View Post
    Have you tried increasing your feed? I know it sounds counter intuitive but I dull or melt bits if I feed too slow. I'll feed faster but I have to decrease the DOC. You should have some decent sized chips coming off to carry away the heat. If you are making dust, you are feeding too slow. I've also increased my bit life by at least a factor of ten. I machine carbon fiber, G-10/FR4, and aluminum all with no coolant or air assist. I'm also using a single flute bit which is a big help. Blowers work great for clearing chips, but if you need them to cool the bit, you might be able to do better by adjusting your feeds and speeds.
    Apr 2013
    canada
    I have tried a lot of different feed speeds. I either break the bits by going to fast or break the bit by going to slow because they heat up. I can reduce the DOC, but this wears the bits down just as fast, just now I am only wearing down the tip of the bit. This setup has shown the best results for tool life and quality of cut. I moved on from using endmills, such as single, and double and am now using diamond cut and chip breaker bits that seem to be better suited to the task. The endmill were more expensive and lost there edge faster.
    Jun 2012
    I understand. The diamond cut and chip breakers do heat up more because their geometry doesn't allow as efficient heat dissipation. I can see why air would be good on those. I use them on composite materials on occasion because they don't leave a burr on cut edges like the endmills.
    Jan 2007
    that pump would do just over 2 cfm, but realize there is no pressure to speak of. As far as chip removal and cooling it would not be a good option.
  7. #7
    Member jalessi's Avatar
    Feb 2007
    Question Re: Air blower for cutting
    Is it safe to use pressurized air machining carbon fiber composites?
    I would be terrified about generating airborne carbon fiber dust.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  8. #8
    Member Azalin's Avatar
    Mar 2014
    Turkey
    +1
    I'd use water on CF. Try not the breathe the dust.
  9. #9
    Jun 2012
    Quote Originally Posted by jalessi View Post
    Jeff...
    Quote Originally Posted by Azalin View Post
    +1
    That's a good point! A diamond cut endmill makes much more dust than a single or two flute.
  10. #10
    Gold Member LeeWay's Avatar
    Jun 2004
    Wouldn't it be better to remove the dust with a vacuum or dust collector instead?
    Then it's not suspended in the air in the shop. It would also assist in the cooling of the tool, though not like direct air might.
    Lee
  11. #11
    Mar 2014
    Turkey
    The point is that CF particles are very tiny and once you breath it sticks to the lung. Stays there for years.
    Sent from my GT-I9300 using Tapatalk 2
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
  12. #12
    Member awerby's Avatar
    Apr 2004
    Azalin and Jalessi have a good point. You really don't want to blow that stuff all over your shop, or breathe tiny particles of carbon fiber. Use flood cooling to capture the particles rather than disperse them. It will also lubricate and cool the cut.
    Andrew Werby
    https://computersculpture.com/
  13. #13
    Jun 2004
    I am afraid that without high volume flooding, you will be doing more harm than good to the tool. You would be recutting carbon paste. I think a good dust collector is the way to go. With a low micron filter. Then again, I haven't cut CF. The phenolic and fiberglass that I have cut would be better served by dust collection.
    Lee
  14. #14
    Apr 2004
    I wasn't talking about dripping the coolant on - yes, you'd need a pretty good stream to dislodge the particles and remove them from the cut. You'll want to have a filter on the sump to catch them as well. But I don't think the CF particles are as challenging to remove as much denser metal particles would be, yet flood cooling is used commonly in VMCs to blast chips of steel out of the way. And I think it would be more effective than letting the particles disperse into the air and then trying to collect them.
    Andrew Werby
