Originally Posted by
handlewanker
Hi, I think I did say that..... more or less......if it cost more to make one then buy one.
The whole point of making a machine is to save money........there being many good designs and builds that are complete packages and turnkey with warranties.
Making one to your own design is an exercise in what not to do next time.
If it's a walk down the construction road because that is what you need to satisfy a need to occupy your creative desire then cost is irrelevant.
I think the popular 6040 aluminium built CNC router (moving gantry) on EBAY, going for around a grand and a half, is a good guideline as to how much you won't save by a DIY approach.
You need to be practical and evaluate what it is you need to do.
The only real bit you're going to save on is the frame.....all the other parts are buy in and will cost that much more as individual items with separate shipping costs.
If this is speaking heresy........I did say a practical approach.
The end product, whatever, only has to machine soft materials with a small work envelope, so going to extremes of frame design is not a criteria that needs rocket science and exotic materials to achieve a modicum of success.
I would even go as far as stating that, if the machine was made with wood as has been done very successfully before, the outcome will not be streets behind or lacking in any capability way at all.
Attached is a photo of a very neat moving table CNC router by.......another poster.......and uses wood for the main frame materials......all other parts are buy in off the shelf items.
There is another machine, (photo attached), The Nomad, also in wood, that was a Kickstarter project I think, and is commercially available, but the design is quite interesting as it has the machine completely enclosed in the frame that forms the enclosure.
You have to be crystal clear at the outset as to what you want to have at the end.
Ian.
