Is it just me? SDP-SI site not working
Can someone try to use the center distance calculator on the sdp-si site?
It won't work for me anymore.
https://sdp-si.com/eStore/CenterDistanceDesigner
Just wondering if they are having problems or it is on my end.
Thanks. Similar Threads:
Re: Is it just me? SDP-SI site not working
Just worked fine for me.
Ubuntu 14.04 LTS, Firefox 37.0.2.
mark
Hmm. Thanks.
They must not like me anymore. I've tried on 2 different computers on 2 different networks.
I'm not able to choose a pitch, or any pulley sizes.
I will try another browser and see what happens.
Thanks again.
it is looking java issue.. either your java , or the application is specified to a java version..
try to looking for older java version, and uninstall the one on your computer
then install the older..
on other hand
timing pulleys has dxf drawing.. so with that you be able to find the distance.. not 100 percent but very close
if you cant get working, then you can use other sites calculator..
Calculators :: Timing Pulley Distance Between Centres Calculator - Technobots - Electronic Components & Mechanical Components
Belt Length Calculator | B&B Manufacturing
FingerTech Robotics - How-To - Pulley & Belt Calculator
Forum Rules
