Yes I have.
The diagram above is not correct. The regulator needs to connect to the tank, and the tank needs to connect to the cylinder. It will not work with the regulator between the cylinder and the tank.
The tank needs to have at least 20x the volume of the cylinder, more is better. My cylinder is about 8 cu/in and the tank is about 1100 cu/in or about 135x the cylinder volume
