I am planning on buying the cad cut cnc router plans within the next month. I am running pretty tight on funds to buy all the necessary components . Is there many things that can be started that would require say less than $500 but would keep me busy on my spare time untill i saved more money up? I guess what im getting at is does a person need to buy say the rails or other high $ items at first??? Thank you for all input
The frame will cost you about 250-300 dollars. You will spend a good amount of time on the frame so start there and it needs done first anyway !
You could then buy your electrical cabinet, some D-Plugs,Wire, Terminals and start doing some wiring.
