You might be able to get a little better price for those motors on Ebay. The seller is Deepgroove1 I believe. These are the same motors that Xylotex sells. But you'll probably have to make the wiring harnesses yourself.
great, are those nema 23 motors or did you have to make a bracket to hold them?Originally posted by marvinstov
Yep, my 3 axis board and 3 motors were were about $190.00. I'm using the Xylotex board, the Pac Sci steppers from Xylotex, and Turbocnc and it works great. If you have problems with setting it up, Jeff is really great about helping you get going. I'll be glad to help too if you get one. I'll let you know when I receive my other motors. The MaxNC worked fine but just didn't do what I wanted it to. Jogging was too slow and I was used to using Turbocnc.
Marv
UCCNC 2017 Screenset
Where did you get the 210 oz motors and how much were they?Originally posted by marvinstov
ullbergm,
I have a Cheap CNC machine, CS-12-24P. I tried the motors, driver/power supply and software that came with it and could only get about 10-12 IPM. I sold the motors, driver/power supply and software. I tried my Xylotex setup, 3 axis board with a 30V power supply, 116 oz/in motors and could easily get 50 IPM with the 1/4x20 lead screw so I ordered another Xylotex board and ordered some 210 oz/in motors to try. Motors are not here yet.
Marv
ullbergm,
The motors are from Dan Mauch at Camtronics and yes they are size 23. They were a little pricey ($119.00 ea) but it's a hobby. Might could have gotten them cheaper if I shopped around but I didn't want to wait. Besides after selling the stuff that came with the Cheap CNC machine, I have money left over to buy cutting tools with.
Marv
Hey Ullbergm, about how thick is the HDPE plastic that your cheapcnc is made of? In your picture it looks like it would be about 3/4" thick. Their earlier model was made with MDF boards, then they changed to plastic.
Thanks Pookie
Pookie,
Don't know about his but mine is 3/4"
Marv
Mine is the same as marvinstov, 3/4.Originally posted by Pookie
Thanks Pookie
Sorry for the delay in responding to you, i've been out of the country.
ullbergm
How's your machine going?? Got my new motors installed Saturday, cutting wood as we talk.
Marv
Good, i've been out of the country for the last 10 days so i havent done much with it.Originally posted by marvinstov
ullbergm
Marv
What kind of results are you getting with the 210 oz motors?
Well, I can get about 30 ipm rapids now. The Z axis wont go that fast, sounds like it is binding or something but slow it works ok. It will do about 15 ipm. If I am cutting at 25-30 ipm with some drastic Z moves (more than 1/4") it will lag behind, may be the way the code is written. The 116 oz/in motors on my other machine did just as well when I tried them as the 210 oz/in that I just put on. I really like it now. I don't do that much cutting at 30 ipm but it is nice to have that kind of speed for rapid positioning, etc.
Marv
cool. I've got some 180 oz motors and im thinking about getting a xylotex controller, the owner said that he thought it'd be able to control my motors just fine.Originally posted by marvinstov
Marv
Any suggestions where i can find 30v power supplies at a resonable price?
so are you getting lower rapids with the 210 oz than with the 116 oz or was it a typo earlier?I tried my Xylotex setup, 3 axis board with a 30V power supply, 116 oz/in motors and could easily get 50 IPM with the 1/4x20 lead screw so I ordered another Xylotex board and ordered some 210 oz/in motors to try.
ullbergm
Forgot, have you noticed that you cannot gouge the table unless you are using extra long bits? I have to block things up sometimes just so I can make all the lower cuts without bottoming out on the Z axis.
Marv
i've mostly done some engraving so far. But when i did some thru cuts i put the stock on a scrap piece of mdf, because i didnt want to cut the table. i haven't really looked at how close i've come to bottoming out on the z.. i'll take a look at it next time i cut something.Originally posted by marvinstov
ullbergm
Yes, I get somewhat slower speeds than with the 1167 oz/in motors. Those motors that Jeff sells at Xylotex are hard to beat, price and power. As for the power supply, I made my own. Toroid transformer and some large caps with a bridge rectifier. Found some great enclosures that are for external hard drives (four will fit in the enclosure). They came with a 5v and 12v power supply inside, great for logic and some 12v lighting and fans. Transform, caps, and board all fit in nicely. I did a little overkill on the transformer, about 31 volts at 18 amps. Enclosure, transformer, caps, connectors and all was less than $100.
Marv
sounds interesting, do you have any suggestions where to start as far as information about building a power supply. It's always been one of those things that i've stayed away from because of the power stuff, but i think im ready to give it a shot now. (i have more experiece with electronics now that i used too)Originally posted by marvinstov
Somewhere in all these post, there is a schematic for one. Real simple, just a transformer, cap and bridge rectifier. I'll look for it.
Marv
ullbergm
I posted some pictures of my power supply in the photo section. Has the Xylotex board mounted inside too.
Marv
I used a 22 volt toroid transformer, 34,000uf 40V cap, and 50v bridge rectifier. Use this link and look on page 3.
http://www.geckodrive.com/ycom/docum...r_supplies.pdf
opps, that didnt come out right.
well it seems that the link is too long. Go to the Gecko Drive site, click "Support" and there are a lot of papers there with lots of info, one is power supplies.
