Router Bits and EndMills: Pictures, Descriptions, and Uses - Page 23
Page 23 of 23 FirstFirst ... 1320212223
Results 265 to 273 of 273
Thread: Router Bits and EndMills: Pictures, Descriptions, and Uses
  1. #265
    Apr 2009
    Default Re: Router Bits and EndMills: Pictures, Descriptions, and Uses
    Quote Originally Posted by ifeliciano View Post
    Ouch!. $150.
    That's a cheap one...
  2. #266
    Sep 2011
    My 4'x8' table has a Bosch Colt motor (1hp, 16,000 - 35,000 rpm, 1/4" collet). I have been cutting wood with it and would now like to cut some thin mild steel sheet (< 26ga) and some 6061-T6 aluminum sheet (< 0.040) with it.
    What bits should I use (specifically)?
    What rpm?
    What feed rate?
    The table doesn't have a vacuum surface so I like to use down-cut bits to keep from lifting the sheet.
    Thank you for your time,
    Dave
  3. #267
    Apr 2009
    Quote Originally Posted by davecove View Post
    What rpm?
    What feed rate?
    Dave
    I think for steel, you may have issues with the too high a spindle speed and not enough power. For the 6061, I have some parameters listed in the first couple pages (and in the descriptions in the videos), and I'd use a single-flute spiral O.
  4. #268
    Mar 2003
    Shelby Township
    These bits are made for cutting steel
    https://www.toolstoday.com/cnc-route...end-mills.html
    You're going to need to take really light passes, and keep it lubricated.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  5. #269
    Sep 2011
    Quote Originally Posted by ger21 View Post
    My first project is cutting decorative shapes out of 31ga galvenized steel roofing. Do I still need to lubricate? Or just watch my feed speeds?
    Dave
  6. #270
    Registered LouF's Avatar
    Sep 2011
    I would lubrication.
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  7. #271
    Aug 2011
    Hopefully this is a quick one for a guru..
    Buddy needs 3/16 acrylic cut with a 20deg edge. He has given me a 20 deg, tapered endmill, 3 flute. At the tip it is 0.125" with a 0.500" depth/cutting edge
    https://www.mcmaster.com/#8936a971/=1ckjmzx
    What would be a good starting point for Feed and Spindle RPM (I'm using Bosch 1617 router). He really hasn't given me much scrap for test cuts so I would like to at least get in the parking lot, if not the ballpark before I test.
  8. #272
    Mar 2003
    Shelby Township
    I would rough cut it a little oversize with a 1/4" 1 or 2 flute upcut, to provide clearance for the chips. Otherwise, you'll likely get a lot of melting.
    Set the router to it's lowest rpm, and somewhere around 100ipm.
  9. #273
    Member Biggs427's Avatar
    Feb 2016
    I had some aluminium profiling and pocket to do in 1/8 alu. For this I usually use a yonico 31011-SC 1/8 cutter for or Onsrud 63-610 o-flute when I need better surface finish.
    I decided to give a try to HRC tools single flute cutters since I'm using their spot drills and chamfer cutters since one year and they do a decent job. I ordered two of their 3.5mm, 10mm LOC cutter. It is about the same price as Yonico and half the Onsrud.
    First, one is really 3.5mm the other is a couple thou off more like 3.4mm... Not a really good start.
    For pocketing, it does an ok job when climb cutting but seems to tears material instead of cutting it when doing conventional cutting. A first for me...
    When profiling it makes the same sound as a dull cutter and I ended up with welded aluminium on the cutters. 30 bucks wasted.
    I took an old Yonico to finish the job and I did manage to finish the job even if the cutter was a little bit dull.
    The moral of this story, stay with trusted brands.
