My First Router - Page 7
Page 7 of 7 FirstFirst ... 4567
Results 121 to 137 of 137
Thread: My First Router
  1. #121
    Jul 2003
    Owensboro, Kentucky
    Default Re: Fred Flinstone 2 ?
    Originally posted by rmtucker
    Just call me Fred Flinstone.
    I never in a million years thought my wood router would cut this with no problems.
    This is really opening my options up.
    The renishaw probe made this uneven rock a boon to draw and cut.
    Mark
    http://website.lineone.net/~rmtucker/
    awesome
  2. #122
    May 2003
    uk
    Default Yet another rock
    Here is rock number 2
    It's still wet so not too much contrast yet.
    Kong this was done at a feedrate of 1000mm/min,it would probably do 4 times this but i can't nip my bum cheeks any tighter if you get my drift!!!!.
    Mark
    Attached Thumbnails Attached Thumbnails My First Router-rockexample2-jpg
    http://www.weardalecnccarving.co.uk
  3. #123
    May 2003
    uk
    Default Side view?
    Just another view to show the contour of this thing.
    Mark
    Attached Thumbnails Attached Thumbnails My First Router-rockexample2a-jpg
  4. #124
    Jun 2003
    U.S.A.
    Mark,
    ok how are you getting the router to follow the contour of the stone? I am wanting to do something like that but am having trouble figuring out how to get the router to compensate for the varience in the surface. Thanks Ron
  5. #125
    May 2003
    uk
    Default Variable Contour.?
    Ron
    I probe the surface of the rock first and read it into my cad cam system then project the toolpaths on to it.Then post back out to mach2 and machine.Mach2 makes a superb job of probing and machining,But i think it screwed my router bearings.
    Maybe just Crap bearings.I will check tomorrow.
    Mark
  6. #126
    Apr 2003
    Mark,
    What are you milling the stone with? Wet?
    I tried engraving a piece of granite tile. I put water on it and it still lit up my carbide cutter. It was just an experiment though. I guess diamond cutters are the only way.
    Thanks,
    Chris
  7. #127
    May 2003
    uk
    Default Wet cutting?
    Chris
    The stone was just wet off washing,It was cut dry with carbide with no problems.The cutter was just a 6mm shank with a 4 sided point ground on it (like a pyramid).
    Mark
  8. #128
    May 2003
    uk
    Default Long time no post?
    Hi Fellas
    Just getting back to my machine after months of other problems.I am going to build a congreve clock on the machine next See link for example.(http://www.williamcongreve.com/).
    Thought i would maybe cut all the parts in one go ie,place sheets of brass on table 1/16" thick,3/32" thick etc.
    Although the turned parts would have to be done on the planned cnc lathe.
    Just tried a bit aluminium 1/16" thick and cut an example , it worked a treat.
    I was thinking of maybe serializing my efforts on the zone if admin would maybe tell me where or which section/forum.
    I need to get some serious cnc'ing done i think i got withdrawal symptoms.
    Mark
    Attached Thumbnails Attached Thumbnails My First Router-dscf0021-jpg
  9. #129
    Apr 2003
    UK
    Good to have you back Mark, I am sure the boss would love it if you would write it in the form of an article, which could then be posted in the articles section somehow! There was a post a little while ago asking for articles, but I lost track of where it is
  10. #130
    Mar 2003
    Shelby Township
    How'd you hold that thing down to cut it?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  11. #131
    May 2003
    uk
    Default Snap offs?
    Ger
    I cut the inside first by clampng around outside then milled around the outside and left snap offs (Bridges) in 4 places about .004" thick so the job did not fall out.Then when complete you just press the job out of the plate.
    Mark
  12. #132
    Registered cncadmin's Avatar
    Mar 2003
    here you go
    Attached Thumbnails Attached Thumbnails My First Router-hf98442-jpg
    Thank You,
    Paul G
    Check out-
    [URL="http://www.signs101.com"]www.signs101.com[/URL]
  13. #133
    May 2003
    uk
    Default Cnc Router Website updated
    Well i am taking the plunge and designing my own website around my homebuilt cnc router and my clockmaking projects.This is going to take up an awful lot of my time so i will be looking at the amount of visitors to my site and any feedback to see how far i should take this thing.
    I am also hoping to update and give better descriptions of the building of the cnc to help some of the newbies out there.
    Cnc Zone has been a source of invaluable help and encouragement to me and would like to thank all who answered and put up with my dumb questions.
    I would say that i have finished the Cnc except for an operator panel and handwheel.
    Please Remember that the website is under construction and will be changing on a daily basis so your patiance would be appreciated.
    Once again thanks to all and i will still be lurking around the cnc zone every day.
    Regards
    Mark
  14. #134
    Gold Member chuckknigh's Avatar
    Apr 2003
    Looks good, and I would like to see more about the Congreve clock you have shown. The history page just displays the word "History." :-) Of course, I'm a clock nut.
    It looks like a very good beginning to a very good site.
    Say, how did you engrave that rock? Did you design a toolpath to follow its contours? It looks like you followed the surface down the "step."
    -- Chuck Knight
  15. #135
    Registered jeffs555's Avatar
    Jun 2004
    Mark,
    I am also quite interested in your clock. I knew about Congreve's rockets because you launched them against us nearly 200 years ago :-) but didn't know he invented a clock. I looked up his clock, and it is a most interesting design. I had never heard of a rolling ball clock before. It must be interesting to watch one in operation. I will eagerly watch your progress on your web site.
    Jeff
  16. #136
    May 2003
    uk
    Default Website Updated ?.
    Hi Guys
    Just follow the congreve project links on my website to see progress on the congreve clock.
    Regards
    Mark
  17. #137
    May 2003
    uk
    Thumbs up I found a use for my Router at last
    Hi guys
    I have found a use for my cnc router at last,Go to my web page at:-
    in the march and april sections of the vwtrike build.
    It may not look much at the moment but when i start on the engraving,the yokes and anything else i can fit on the machine will be covered.
    It May give someone some ideas.
    Regards
    Mark
My First Router
My First Router
My First Router
