Build Thread One Big, One Smaller ... My 1st builds - TrickyCNC - Page 9
Page 9 of 9 FirstFirst ... 6789
Results 161 to 162 of 162
Thread: One Big, One Smaller ... My 1st builds - TrickyCNC
  1. #161
    Aug 2011
    UK
    Got my 1st machine error last night.
    I was cutting 12 shapes out of 1 sheet.
    It cut the 1st as normal, then I heard it stall. (1st time it's stalled on me ! )
    I stopped it and jogged back and forth a bit, everything seemed ok
    I re-homed and restarted, and everything was moving 2 or 3 times faster ??
    I dropped the EMC max speed limit slider down to 150IPM and it carried on cutting ok.
    It actually made the curves cut at 150IPM too, which usually cut a lot slower, maybe 50-60 IPM on some curves, so this was a good side effect, which I will look at reproducing.
    I loaded the next file for the next sheet, and it was still cutting at silly fast feedrates.
    I'm using EMC, and am guessing it's a setup file glitch, that might just sort itself out today after it's been shut down and rebooted.
    Anyone had anything similar happen to them ?
    Any ideas why it might have changed settings halfway through a file ?
    I haven't checked the file or settings (or anything yet) as it was late, and I just shut down after it finished cutting
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
  2. #162
    Aug 2011
    UK
    Default Re: One Big, One Smaller ... My 1st builds - TrickyCNC
    lockdown reminiscing .. wondering if I should start making things again after a couple of years off ! ?
