Scott,
Hi! Looks like you've made some good, solid choices. The motors I'm not familiar with-do you have a link? While your at it, what dimensions are you considering, what machine configuration (moveable gantry, fixed gantry, etc), and what will you be machining? Wood, aluminum, other? The more info you can provide, the better others can help. If you go to the Geckodrive site Marris has a .pdf file on power supplies-might be a good place to start. I've got the G210 units and absolutely love them. He has since released newer, updated units though. The answer to your IPM question depends on some design variables. The size of the spur gear, power supply, quality of build, and the PC's ability to output an adequately fast pulse train to the Geckos, among others. Come back with some details!
Lance
