Darren,
8020 extrusion has been mentioned by others as an effective and easy way to build your frame, as well as your gantry. In a bit of shameless self promotion, I might suggest using the setup described on my website (www.cncrouterparts.com) for acme screws and end bearings, which just happens to work well with 8020. Cheap, easy to assemble, and adjustable. With the motors you have, high pitch ACME screws (which are far more efficient than standard 1/2-10), and anti-backlash nuts from dumpstercnc, you'll have a pretty solid machine without breaking the bank. You can upgrade to ball screws later if you feel the need.
Ahren
