Newbie: CNC controllers
Results 1 to 6 of 6
Thread: Newbie: CNC controllers
    Jul 2003
    Skokie, Illinois
    Cool Newbie: CNC controllers
    HI All,
    Been lurking on this site for awhile. Really impressed with some of the machines being built. I've been working on a cnc setup of my own using aluminium, rollerblade bearings and a 2 pairs of linear THK slides. When it gets closer to completion, I'll post some photos. Till then, I 've got a few questions...
    I'm trying to determine which controller would be the best to consider. At this point since this is my first machine, I'm planning on going with stepper motors. I have a pair of Nema 34's, so I'll probably use them for now.
    I have been considering either using the FET3 controller found on stepper world or the xylotex controller.
    What are your opinions on these two??
    Thanks in advanced.
    --Mike
    May 2003
    Tucson,AZ
    mbogucki,
    I had the same question almost a month ago.....
    I did not actually post it.. but I could not make up my mind...
    I enventually deside on xylotex, I'm not sure that the FET board has microstepping...
    but I did not like that I had to figure out and use some kind of limiting resistor...
    I can only guess that those resistor can get very hot by the heat sinks I've seen on them..
    (I'm loving my xylotex board.. ( Motors do not even get warm, I put to small fans on the driver chips but they also do not seem to get hot. )
    well just my 2 cents !
    Luis
    Registered WOODKNACK's Avatar
    Mar 2003
    Maine
    I also have a xylotex board and am loving it! Very good for the money!
    My little piece of the web!
    http://users.adelphia.net/~wjdupont
    Registered balsaman's Avatar
    Mar 2003
    The FET 3 is quite good, but I would also probably get the Xylotex, as it doesn't require the resistors, so it's easier to use a higher voltage power supply.
    Eric
    I wish it wouldn't crash.
    Jul 2003
    Skokie, Illinois
    Thumbs up
    Hi All,
    I wanted to express my thanks to all that have replied with your suggestions.
    Hopefully if all goes well, in about a week or two I'll be ordering myself a xylotex board.
    Thanks again!!!
    --Mike
    Registered HomeCNC's Avatar
    Mar 2003
    Stepper world controllers are all Uni-Polar controllers. I would go with a Bi-Polar chopper controller. I think the Xylotex is one.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
