Leavme- If you want the v1.5 that is no problem. The first thing to do once you get the SuperPID is connect the 5v power and check the version it already has. If it is not already a v1.5 email Val at the SuperPID website arrange a chip exchange or reprogramming etc.
SScnc- Hi, yes the SuperPID comes with an opto sensor and 2.5 metre length lead standard, all included in the price. If you want extra metres of cable there is a box there you can select on the order page and say how much extra cable length you need. Likewise some people order a temperature sensor (which is not included in the basic product).
Walky- Good work! That opto sensor is a bit larger than ideal (as we discussed) but you have got it sorted out fine. Your white paint is very white and matte, and your black/white paint areas are reasonably large. It looks like you painted the inner race of the bearing and the shaft (which is fine, and makes a larger painted area). Your bargraph readings are excellent so there should be no problems with that sensor. Like I said before the SuperPID is designed to be pretty tolerant of sensor type.
You mentioned about adding more epoxy later, one tip would be to use silicone (silastic) instead of epoxy, it is easier to remove and also sticks better especially when things vibrate like router plastic parts. Silicone is also easier to shape, as epoxy tends to run or drip when in larger quantities.
Wow that's a really nice bit of engraving! I have never seen that type of raster engraving, it looks like the old 45 degree "screen" that we used in the days before desktop publishing when photos were "screened" to make them into dots ready for offset printing! It's very cool, kind of a classic look and being engraved it should last forever.
