Super-PID new low-cost router speed controller - Page 120
Page 120 of 120 FirstFirst ... 2070110117118119120
Results 2,381 to 2,396 of 2396
Thread: Super-PID new low-cost router speed controller
  1. #2381
    Sep 2006
    Default Re: Super-PID new low-cost router speed controller
    The VS and POT are jumpered together, per the instructions. There is nothing connected to the P5 terminal. I still read a voltage on the PWM terminal.
    Are you suggesting the VS and POT should NOT be jumpered together?
    Sent from my iPhone using Tapatalk Pro
  2. #2382
    May 2010
    Quote Originally Posted by rlrhett View Post
    Thank you, but It is called a RAMPS 1.4 shield for the Arduino. That is short for “Rerap Arduino Mega Pololu Shield”. It is actually quite a popular and established controller. It is used on literally millions of machines, primarily in 3D printing and laser cutters, but also for popular CNC machines like the ShapeOKO. It is NOT a ramping voltage.
    The controller is outputting 0-5v PWM signal from 0% to 100% duty cycle. In fact, Arduinos are incapable of producing an analog output.
    I can’t explain what an Arduino is here, but more information can be found here:
    https://reprap.org/wiki/Arduino_Mega_Pololu_Shield
    Perhaps someone with a better idea of what an Arduino/grbl setup is has an idea? I am especially confused as to why the PWM input pin on the SuperPID has a positive voltage when not connected to anything.
    I’ve tried to be very precise as to what my setup is, but they say a picture is worth a thousand words. The arrow I drew appears to point to the PG terminal, but I mean the PWM terminal. That’s where I’m getting an unexpected voltage.
    I'm well familiar with the Arduino, primarily the Uno. As long as your Arduino PWM control line and the Arduino GND are connected as you show, it should be working fine.
    In terms of what you are measuring on the Super-PID 's PWM pin, as long as your PWM supplied 0-5v signal is pulling the PWM pin down to 0v, it doesn't matter. I'd have to open my Super-PID enclosure up to see if there is normally 5V on the PWM Super-PID port when no external signal is applied.
    Al-the-man states that an analog voltage from a potentiometer wiper could be used to control the router speed. But you are not using the analog option. So you are on the right track for implementing PWM control.
    If your Arduino PWM output is producing positive going 5v pulses from 0v, the norm for off, with narrow pulses widely spaced at low speeds and wider pulses more closely spaced for higher speeds (understand that I mean the pulse interval is a constant frequency) then that is what Super-PID is expecting. Super-PID has no knowledge or interest in how your G-code producing or reading software interprets your Arduino PWM pulse train. That is something that has to be dealt with (configured) solely in the G-code producing/reading software aka RAMPS.
    Sounds like you need to invert the PWM signal sent to Super-PID. That your getting a speed change that is inverted to what is desired means you are close to having it work properly.
    airnocker
    Everything depends on everything else
  3. #2383
    I recently accomplished the attached wiring so that I can easily switch between cnc and laser on my openbuilds lead 1010. I use the dewalt 611. I'm interested in the super pid and they told me that I should double check here about how super pid wiring would be added to my attached diagram.
    Super pid said: He said the IOT switch can
    probably connect to Super-PID RUN terminal. May need to use a relay.
    I have a response in the openbuilds forum that says:
    You can add it, same as your diagram, the PWM signal wire to the SuperPID passes through your switch
    Just remember to set $30 gnea/grbl so the spindle speed scales correctly
    I, however, and not well versed in this type of thing. And need it explained in layman's terms. Many thanks for any pointers.
    cheers
    stuart
    Attached Thumbnails Attached Thumbnails Super-PID new low-cost router speed controller-89913195_10221956457280473_4910739931208351744_o-jpg
  4. #2384
    May 2010
    Can you please provide more specific information for which Blackbox PWM switch you are using and why you would even need an IoT switch if you want to replace it with the Super-PID. What is the black wire "spliced" together from the PWM controller to the IoT and J Tech Laser Controller? are the components shown in your diagram purchased from the openbuilds 1010 website?
    Are you aware of the modifications you would need to make to your Dewalt 611 in order to use it with the Super-PID?
    What CNC software are you using to control the machine?
    airnocker
  5. #2385
    Jan 2007
    I am trying to hook up and get running the Super PID on my CNC Machine. I am using a Porter Cable 892 Router. My setup uses a Gecko G540 and ethernet smooth stepper running Mach3. I am attaching screenshots from Mach 3 as well as my wiring diagram for anyone to look at and maybe see what I am doing wrong. I can run the router in POT mode but when I try and control (start and Stop) the router through Mach 3 it does not work. I am not sure if it is my wiring done incorrect or if I have a setting in my software that is not correct. Any help would be great.
    Attached Thumbnails Attached Thumbnails Super-PID new low-cost router speed controller-screen-shot-2020-12-08-8-33-a   Super-PID new low-cost router speed controller-screen-shot-2020-12-08-8-32-a   Super-PID new low-cost router speed controller-screen-shot-2020-12-08-8-34-a   Super-PID new low-cost router speed controller-screen-shot-2020-12-08-8-35-a
    Super-PID new low-cost router speed controller-img_0061-jpg   Super-PID new low-cost router speed controller-superpid-v2_gecko_g540_all_wiring_connections-2-jpg
    Attached Files Attached Files
  6. #2386
    May 2010
    Quote Originally Posted by rstrease View Post
    Can you confirm that you have made the modifications to your PC 892 router for the optical RPM sensor feedback control?
    airnocker
  7. #2387
    Jan 2007
    I have made the changes to my router.
  8. #2388
    May 2010
    Great!, Thanks for confirming. We have the same router but we use different break-out boards, so first I'll share my comparable screens that you posted in your setup. I use the CNC4PC C1R12 parallel port break-out board.
    Here is my screens:
    Super-PID new low-cost router speed controller-g2-spindlesetup-jpg Super-PID new low-cost router speed controller-g2-motoroutputs-jpg Super-PID new low-cost router speed controller-g2-outputsignals-jpg Super-PID new low-cost router speed controller-g2-pulleyselection-jpg Super-PID new low-cost router speed controller-g2-genconfig-jpg
    I'm going to take a look at your Gecko 450 specs and get back to you. Your Super-PID drawing does not indicate what pin on your Gecko the RUN pin from the parallel port connects to.
    EDIT: Now I see why you are using the Gecko G540, Please refer to this link to help guide you. If you have questions about what Roman is saying, please ask. https://www.cnczone.com/forums/diy-c...-superpid.html
    Attached Thumbnails Attached Thumbnails Super-PID new low-cost router speed controller-g2-spindlesetup-jpg   Super-PID new low-cost router speed controller-g2-motoroutputs-jpg   Super-PID new low-cost router speed controller-g2-outputsignals-jpg   Super-PID new low-cost router speed controller-g2-pulleyselection-jpg
    airnocker
  9. #2389
    May 2010
    I'd add the recommendation to measure the voltage from the super-pid 5v output to your VFD+ terminal to confirm that it is +5v. Then measure the output on the VFD Output pin as your CNC control software changes its RPM signal from a low to high rpm. It should stay in the range of 0-5v. Double check your grounds between the Geckgo, Super-PID and your break-out board or computer's signal ground. Signal grounds should NOT be connected to Earth grounds as well.
    airnocker
  10. #2390
    Jan 2007
    Quote Originally Posted by airnocker View Post
    I will try all these and see what happens. Thanks for your help.
  11. #2391
    May 2010
    Also remember, that the other link I posted where Romanlini is discussing the use of Super-PID with the Gecko controller, he said the normal VFD+ reference voltage is 10volts, not 5. Using 5v worked form most but not all Gecko users. He goes on to describe that a voltage divider is required on the VFDout to drop the voltage down to 5v when using 10v for the VFD+ .
    airnocker
  12. #2392
    Jan 2007
    When I run it in manual mode (pot) I get power to the router and I can change the rpm up and down with the control knob with no issues. When I try and switch to allow the PC to control the router no power is output to the router. It’s strange.
  13. #2393
    Member lancut's Avatar
    Nov 2008
    Just run into this thread, I have the same setup and is running faultlessly. If you still struggling with this I try help you. To start read my posts here from the beginning in this thread, I was struggling with this just like you are. To start with, my setup use 5V, Spindle On/Off (M8/M9) is controlled by Solid State Relay. Hope this helps.
    My 2¢
  14. #2394
    Nov 2008
    "To start with, my setup use 5V, Spindle On/Off (M8/M9) is controlled by Solid State Relay. Hope this helps."
    Cant find a way to edit post.
    It should be M3/M5. Sorry.
    My 2¢
  15. #2395
    Jan 2007
    I can now control my spindle thru Mach3 but I can only get it to work if I switch it to Manual mode. When I do this it starts running the spindle at 5000 RPM and does not stop. I can change the speed in Mach3 no problem but when I go to turn off the spindle in Mach 3 it stops the current speed and goes back to running at 5000 RPMs. I can also manually go into POT view and change the speed there with my knob. For some reason when I switch over to PC mode to let mach 3 fully control the spindle nothing happens.
  16. #2396
    May 2010
    I can now control my spindle thru Mach3 but I can only get it to work if I switch it to Manual mode. When I do this it starts running the spindle at 5000 RPM and does not stop. I can change the speed in Mach3 no problem but when I go to turn off the spindle in Mach 3 it stops the current speed and goes back to running at 5000 RPMs. I can also manually go into POT view and change the speed there with my knob. For some reason when I switch over to PC mode to let Mach 3 fully control the spindle nothing happens.
    For clarification, my Super-PID is V1, yours appears to be V2. In my previous post, I posted a V2 diagram depicting connections that only shows PWM control signal coming from a PC (such as generated from Mach3 software) but does not show switching between manual speed control and PWM computer control.
    If I'm not mistaken, the diagram you posted previously for your V2 showed the ability to switch between manual pot and PWM computer speed control.
    airnocker
