Spindle Idea - Page 20
Page 20 of 20 FirstFirst ... 1017181920
Results 381 to 383 of 383
Thread: Spindle Idea
  1. #381
    Nov 2008
    Default Re: Spindle Idea
    Saw this review online of the brushed version. It has massive runout, lacks a double-row angular contact bearing in front (so the shaft has up-and-down play), and has an absurd rubber-mount bearing in back. I doubt the brushless is different, but we'd need to see it disassembled to know.
  2. #382
    Dec 2008
    I saw that review during my research and pretty much ruled out the brushed versions tho some seem to be having reasonable results with them. I have not found any information as to the internal design of the brushless versions. Was hoping they corrected the obvious bearing problems.
    Don
  3. #383
    Jan 2005
    Quote Originally Posted by atwooddon View Post
    Don
    Most people should know that this motor has not been designed for use as a spindle, the motor is a standard regular light duty DC motor, with a collet chuck mounted on it, the motor could be used to drive a spindle,but not much use like it is, this does not represent the Chinese water cooled spindles in any way, which are designed as a spindle, they have 3 & 4 bearing models
    The people selling these are just making a buck, taking advantage of those that don't search & get a better knowledge on the subject
    Mactec54
Spindle Idea
Spindle Idea
Spindle Idea
