Mitutoyo touch signal probe
Results 1 to 10 of 10
Thread: Mitutoyo touch signal probe
    Oct 2006
    ireland
    Default Mitutoyo touch signal probe
    Hi all,
    can anyone please help with connection data --pin outs / operating voltage--anything?
    for a mitutoyo touch signal probe no.902329
    Thanks bert
    Jun 2005
    us
    Default mtp1 probe info
    for wiring, with the probe tip facing down, and the connector facing you, the upper left and bottom right pins are an NC switch. the remaining two pins are for the led.
    Dec 2008
    Question I have the same probe but I think a different socket
    Quote Originally Posted by bfreedland View Post
    Uhhh...
    Hmmm.. my probe doesn't have an upper left / lower right...
    it has a sort of upside down 'Y" shaped socket, see below...
    (ignore the hyphen characters "-", used as spacers)
    up (shaft)
    ---O-
    ---O-
    -O- -O-
    down (probe)
    any ideas...????
    Thanks in advance
    john
    Sep 2004
    If you are still looking for information, I have a PDF of the original manual.
    I can tell you that it's a conductive probe, which means that the circuit is closed by a signal passing thru the tip to a conductive item which you are probing, back thru the frame of the machine, etc.
    On the DIN plug connector (end of the cable not plugged into the probe), P1 and P3 are used, P2 and P4 are not used. P1 connects to the shank of the probe, P1 connects to its tip. When the tip couches the work piece it therefore closes the circuit between P1/P3.
    Let me know if you want a copy of the manual.
    Carl
    Oct 2006
    ireland
    Thanks for the info Carl. I would like a copy of the manual. Can you post the pdf. here or send me a copy.. bertietaggart04@eircom.net.
    Bert
    Dec 2008
    Default Yes please the PDF manual
    Have been in calif for a while & just got back...
    Yes please email the PDF manual
    you can direct it to: aff@netmac.net
  7. #7
    Default Re: Mitutoyo touch signal probe
    Hello
    Can you please email the PDF manual for the signal probe no.902329
    you can direct it to: skuterypl@googlemail.com
    Thanks!
  8. #8
    Registered Densoman's Avatar
    Feb 2014
    I see this is a pretty old post but I have one of those Mitutoyo touch signal Probes too. I can't figure it out. It only has 2 wires and it is not a simple NC or NO switch unless it is broken. I got it off EBAY and it looks perfect. If any of you guys has any info I would greatly appreciate it.
    Bart
  9. #9
    Sep 2015
    Hi Carl,
    I got a similar Mitutoyo touch probe (902431). I don't finde any information, please send me the .pdf manual, thank you very much. My email: elcsbetter@gmail.com
    Elek
  10. #10
    Nov 2006
    Looking also, If I get a version I will hopefully host a link.
