Cheap home made Touch Probe. - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 37
Thread: Cheap home made Touch Probe.
  1. #13
    Aug 2005
    Quote Originally Posted by mikegasman
    I use mach3 to run the probe and my machine. The digitizing wizard in mach3 works good
    when probing the writing on the wrench it comes down in the z axes and records the position
    that’s all I’ve done with it so fare it will activate going in the XYZ position.
    Was just sharing what I made with every one who mite want to play with a probe but don’t have the money for it or the time to make a fancy one.
    And I can't tell you how much we appreciate guys like you who share your adventures I would have never thought this was possible to make a probe yourself
    thank you
    Rob
  2. #14
    Registered chronon1's Avatar
    Aug 2004
    chronon1
    That was a pretty cool demo for SW07 .. I watched about 2/3 of it as I dont have the fastest connection - too bad SW is so over the hill $wise.
  3. #15
    Registered mikegasman's Avatar
    Aug 2004
    canada
    Hay Chronon1 I made the probe to make some tale light covers for my truck just one of my projects that might get done or maybe not.
  4. #16
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    I'm not sure if I missed thae answer or not, but have the same question:
    Does the probe need horizontal switching as well as verticle?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  5. #17
    Aug 2004
    canada
    hay Phil I like your site
    not sheer what you mean but it will activate going in the x and y direction when it hits something
    and when its going down in the z direction.
    I can make it’s. it's the explaining that gets me all you know what.
    john
  6. #18
    Moderator Switcher's Avatar
    Apr 2005
    John,
    Nice job on the probe, the machine I run at work has a Renishaw probe on it. It is pretty much what you have made here.
    I was curious to know how much a Renishaw probe would cost (I found this on Ebay)
    http://cgi.ebay.com/Renishaw-Probe-M...QQcmdZViewItem
    So, you know If it cost around $1,000.00 on Ebay. It would cost more If bought new from a Renishaw dealer.
    I think this would be a nice addition to any DIY 3-Axis router table.
    Good Job!
    Jerry
  7. #19
    Apr 2005
    John,
    I've got a question for you, since you said, you are running this probe with the Mach Control.
    Does the Mach Control have a parameter in it to compensate the thickness of the stylus (In the "X" & "Y" direction)?
    Example: If the probe is used to find the edge of a workpiece, will "Mach" take the thickness of the stylus and divide that by 2, so that I get the actual edge of the workpiece (and not an offset edge) ?
    Thanks,
    Jerry
  8. #20
    Aug 2004
    canada
    Jerry
    im no pro at this it’s just a hobby I like making things I looked at the manual for mach it looks like you can do it but I cant tell you how.
    You’d be better off asking in the mach forum.
    Sorry john
  9. #21
    Gold Member
    Jun 2003
    Jerry I can answer you mach3 compensation question tomorrow......I hope!
    Mike
    No greater love can a man have than this, that he give his life for a friend.
  10. #22
    Apr 2005
    Thanks, Mike
    Jerry
  11. #23
    Feb 2007
    Forgive me if you've already mentioned this somewhere and I missed it, but I'm wondering where the wires go that leave the probe? How do they interface with the computer?
    Thanks,
    Jason
  12. #24
    May 2005
    New Zealand
    Quote Originally Posted by jsnbrgg View Post
    Thanks,
    Jason
    You need to run them to one of the inputs on your controller then set your software to tell it this input is a probe.
    Paul
