Removing feed-thru punch from wood die board?
Results 1 to 4 of 4
Thread: Removing feed-thru punch from wood die board?
    Aug 2014
    Default Removing feed-thru punch from wood die board?
    I'd like some advice on how to remove a broken feed-thru punch from a wood die board. The punches are only 1/16" thick so there's not much steel to press against when pressing it out. I'm new to this and wanted to get advice on what the standard procedure is before I try pressing them out with some sockets.
    Jun 2010
    Default Re: Removing feed-thru punch from wood die board?
    Need photo - it does not appear.
    Cheers
    Roger
    Aug 2014
    Removing feed-thru punch from wood die board?-broken-punch-jpg
    Attached Thumbnails Attached Thumbnails Removing feed-thru punch from wood die board?-broken-punch-jpg
    Jun 2010
    Um ...
    What's not visible is how far it is sunk into the timber. That matters.
    Frankly, just looking at it, I would GUESS that brute force and a hammer might be how I would try. Sorry about that.
    Unless of course you can fit a tight mandrel inside it and then apply a bit of torque?
    Cheers
    Roger
