Tripping Breaker on New Clicker Press - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 49 to 51 of 51
Thread: Tripping Breaker on New Clicker Press
  1. #49
    Apr 2015
    Default Re: Tripping Breaker on New Clicker Press
    Quote Originally Posted by iWAYNE View Post
    I didn't check the motor temp.
    The manufacturer now suggests I remove a solenoid in the pump (directional/check valve) to see if it helps, but I doubt that will so I'm not doing that.
    I guess the thinking on this is that it might be starting up under load, in fact it will be the opposite way round, hydraulic load is applied when the solenoid is energised. You could try turning the flywheel by hand, it should turn freely, the hydraulic oil should circulate through the valve back to the tank so and you may be able to see the oil circulating. If it does not look to see if the ram is moving. Make sure you turn it the same direction the motor turns, maybe the valve is sticking.
  2. #50
    Gold Member
    Jan 2005
    I never ran it dry.
    When I ordered the press they told me it would be a week extra time building it because they needed to special order a 110v motor. So either they don't know how to rewire a convertible motor (maybe rewiring one would void the motor warranty?), or their motors are not convertible and had to order a 110v one.
    Do you have a written valid warranty, not for China you don't, they will replace parts if they are faulty, and in most cases you have to return the faulty parts at your cost
    That's one thing out the way, it's good that you had the oil in, the wiring is your next problem, this needs to be corrected, it's not safe they way it is wired
    Is it rotating the correct way, do they have an arrow anywhere to indicate the correct rotation in the video it is under load and it should not be under load at start up, they ask you to remove the solenoid, this is a good idea, as it could be shut when it should be open, this is a good test
    This would indicate wiring or a bad valve /solenoid, so you should do what they are asking
    Mactec54
  3. #51
    Gold Member
    Jan 2005
    A video of the clicker press tripping the 30A breaker on start up.
    I can't tell which way it is spinning in the video, but looks like it is clockwise,
    It is a similar hydraulic unit I just installed from China, and It needed to spin anti-clockwise
    Mactec54
