Dowel pins for punching small holes?
Results 1 to 3 of 3
Thread: Dowel pins for punching small holes?
    Aug 2012
    Default Dowel pins for punching small holes?
    Making a die to punch out a large (8") part from thin aluminum and needing to have several 1/8" holes. The holes don't need to be high tolerance. Am thinking of using some dowel pins with ground off ends for the male side and milling the hole for proper clearance on the female. Is this how it is commonly done? Other ways of doing it?
    Dec 2013
    Default Re: Dowel pins for punching small holes?
    I have used dowel pins as punches for limited use. Given the material you are punching, you would want 1.5 to 2 thousandths clearance on the dies to punch clean holes. The larger the clearance the more the hole edges roll over. I would ream the die holes.
    You might look at Dayton Progress punches and die buttons. Punch & Die | Dayton Lamina Corporation
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2010
    Texas
    If you're not going to buy punches and do it right, at least use something that is through hardened like a drill or reamer blank.
