Milling 50 RC h13
Results 1 to 6 of 6
Thread: Milling 50 RC h13
    Mar 2015
    Default Milling 50 RC h13
    Hey fellas,
    working on milling some 1/2" wide slots in h13 approximately 1/2" deep. cutter is a TiALN coated 3/16 carbide. Right now speeds are 250sfm(ish) feed rates are around 7ipm. chip load is about .0005
    I say "about" because I didnt program it just glanced at the mastercam settings.
    So the tool has a bit of squealing to it, but it seems to be cutting fine. Just want to make it through these 4 slots without killing the cutter. current DOC is .188. should i just go ahead and cut it full depth? Using the mastercam peel path with a 6% stepover.
    Advice is appreciated. first time cutting something this hard.
    Mar 2015
    Default Re: Milling 50 RC h13
    looking around the net, and according to my FSwizard calculator i should be at 8000 rpm and 36ipm. thinking maybe i need to speed it up a little
    Jun 2015
    U.S.A.
    yeah milling hard material isn't as bad as one would think. it's just a little more important that you get your speed/feed/doc correct the first time!
    Registered Tornado220M's Avatar
    Apr 2013
    UK
    too fast and it breaks .... too slow and it can burn out but surely the cutter supplier / manufacture would have that information ? 50 RC isn't that hard, I mill 74 RC parts
    Mar 2015
    So I guess that makes me curious as to where those starting points are. I use fswizard right now on my tablet and it seems to be accurate, i just wonder where they get the values from. How do you know to use 900sfm or 1100? .... lol to think a few years ago 300sfm was scary.
    Jun 2010
    Broken cutters and the mfrs place.
    Cheers
    Roger
Milling 50 RC h13
Milling 50 RC h13
