Need Help! China 3040 parallel port
Results 1 to 9 of 9
Thread: China 3040 parallel port
    Member Bartman01's Avatar
    Jan 2024
    Default China 3040 parallel port
    Hello, looking for help in a way to hook up a Z touch pad, however my machine has no limit switches.
    The board has no provisions for limits or other plugs, many empty holes to soldier wires to the board.
    I did find a program that works with Mach3 for setting everything up and finding the proper pin once hooked up, but recommends pin 15....I tried ringing it out with my meter, but find nothing without power that has continuity.
    Any help appreciated
    Jun 2005
    Default Re: China 3040 parallel port
    You could get a generic Mach3 CNc control board that comes with inputs and outputs, they sell for $40 to $60 on eBay
    Jan 2024
    I've got 2 different boards, but haven't idea what to fo with them. The mill works great like it is, just want to add the Z probe
    I can fix about anything, just never dealt with these before. I repair Tube amplifiers but am self taught...lol
    Jun 2005
    Quote Originally Posted by Bartman01 View Post
    Hooking up and modifying these the CNC control boards is not difficult. Especially if you already do stuff with electronics like tube amplifiers. Post pictures of the boards you have including the one in the machine, I can probably guide you on how to add a Z probe. What software are you running with the mill right now, Mach3?
    Jan 2024
    This is the board I have, just found this .pdf
    https://www.vallder.com/images/product_details_images/mach3_5-axis_board/Mach3-5-Axis-Interface%20Board.pdf
    Jan 2024
    Quote Originally Posted by CNCMAN172 View Post
    Yes, Mach 3 and drawing and post-processing with solidworks
  7. #7
    Jan 2024
    The board in the machine has the 4 pin plugs for the X, Y, Z, A axis that would plug right into the breakout board. It would be wiring the drivers that would throw me.
    Just have to make sure I get the X, Y, Z, A drivers in the correct spot.
    Also has a plug on the back of the power box that plugs into the machine. Not a parallel plug, but similar.but I can always ring that out with my meter for the mototrs.
  8. #8
    Jun 2005
    This board has a tool setter input available, this is all you need to do is configure it for that port/pin. The axis inputs are clearly labeled, very easy stuff.
  9. #9
    Jan 2024
    I see that now that I have a schematic. Thanks for the suggestions. I will hit you up if I have any snags
