imservice cnc router / DeskCNC controller and SV500 servo drives will not jog
Results 1 to 3 of 3
Thread: imservice cnc router / DeskCNC controller and SV500 servo drives will not jog
    Jul 2017
    Default imservice cnc router / DeskCNC controller and SV500 servo drives will not jog
    hi
    i bought a used IMservice cnc router that uses deskcnc controller and sv500 servo drives with servo motors
    its 3 axis
    im having some horrific headaches with thios thing..it is old but the prev owner used it 1 time and stored it ever since
    its in great condition but i cant get any of the axis to jog at all
    when i open deskcnc it opens to machine mode with DRO..the controller is flashing blue which is good...all 3 servo driver boards are solid blue which is good
    when i try to jog the DRO only moves .0001 at a time and the axis do not move...no matter if i have it in step mode or continuous mode the DRO only moves .0001
    i have tried just hooking up 1 axis enoder cable at a time and that has no affect
    ...alll the connections have been cleaned with contact cleaner and all connections look good...i have gone over this about 10 times...
    after 10hrs of working on it for some reason the axis started jogging fine and i then ran some test toolpaths and all was well..so i thought
    4 days later..i went to try again to use the machine and again the axis will not jog ....
    does anyone know anyhting about deskcnc controller?...there is very little info online and imservice went out of business and deskcnc tech support really is of no help.
    i have a hard time believing all 3 servo drives failed at once or all 3 servo motors failed at once and all 3 enocders failed at once
    something odd is going on that i cant not figure out
    like something is casuing interference...today even though axis would not jog a couple times the axis would just randomly move for no reason...very bizarre.
    although i get no movement during jog... if i try to home each axis each axis will just move a very short distance 2 times (.100 or so ) and just stop...x yand z all do this.
    so if home x it will move short distance..stop..then move short distance again and then stop...same with y and z but then other times if i try to home each axis i will just see the DRO move a small amount twice and the axis will not move...
    i also have the latest deskcnc software and latest firmware installed...and i have deskcnc controller generation2.
    i really hope someone can make light of whats going on....its just very bizarre.
    4d4n's Avatar
    Dec 2020
    Default Re: imservice cnc router / DeskCNC controller and SV500 servo drives will not jog
    Hi, I have the same problem
    They gave me that cnc router but I can't get any movement of the axes. Download deskcnc trial mode to test it and if it worked buy it but it doesn't seem to make any move. I was looking for information to make it work with mach3 modbus but I think I'm not smart enough for this operation
    Jul 2017
    i found out issue...it was a bad solder joint at the limit switch cable connector.
