- DeskCNC- Spindle speed not responding
Trying to use DeskCNC to drive a laser, but having trouble changing spindle speed(laser power). Seems DeskCNC will not set spindle speed from G01 command unless the command is the last speed command in file. The G00 may or may not set spindle speed, depending on what is on the next line following the G00 line. Tried changing settings in ini file ,but no luck. Any ideas appreciated. Thanks
Ron
- You may not post replies
- You may not edit your posts
Forum Rules
