- Need Help!- TB6600_T4 Problems
TB6600_T4 Problems
Bought a SainSmart CNC Router 4 Axis Kit, TB6600 4 Axis Stepper Motor Driver, Mach3 5 Axis Breakout Board, 4pcs Nema23 270oz-in Motor from Amazon in late December. It has a TB6600-T4. Just finished building my CNC. All good except I am not getting any voltage out to motors. Put test leads directly on screw connections to Motor’s - No Voltage !
Was running it at exactly 40 volts, then dropped to 30 just as a test. Either way I am getting 2.7 volts from the test ground to each of the four test points. Even checked the 4 round capacitors for each motor connection; showing 38.8 volts. Green indicator lights are coming on for each axis during test. Even A as it is slaved to Y.
Using it with Mach3. Screen indicates movement In synch with the green indicator lights on the TB6600-T4.
Have reached an extreme level of frustration.
Suggestions ??? Help Please.
Note: Same msg submitted to Sain Smart but with order info.
- You may not post replies
- You may not edit your posts
Forum Rules
