When I did mine on my different bob it didn't work either. Turned out my control board was a negative output to axis. So I had to wire my SSD positive to my 5v+ supply and my negative - to the axis pin. Can't remember off hand whether mach then had to be active high or low.
No guarantees cable swap rounds will work for you though.
