TOR Cam cnc any info on parallel port pins
Results 1 to 1 of 1
Thread: TOR Cam cnc any info on parallel port pins
    Dec 2007
    canada
    Default TOR Cam cnc any info on parallel port pins
    Hi
    I got hold of old TOR cam cnc lathe.
    Used in schools (Ontario) to teach cnc machining .
    Any info on pin out or driver board .
    Started with cleaning and then I’m going to probably use Arduino and original drives I hope.
    5v to pin 8 enables the spindle witch is dc 90v .
    Attached Thumbnails Attached Thumbnails TOR Cam  cnc  any info on parallel port pins-0c0bd1cf-cdd5-42f5-b7d5-74f506acb035-jpg   TOR Cam  cnc  any info on parallel port pins-0a5c4c4f-1774-4c47-ad9d-2fbf5f2c66ca-jpg
