Need Help! Auto Z probe work in mach3 setup problems
Results 1 to 4 of 4
Thread: Auto Z probe work in mach3 setup problems
    Oct 2017
    Denmark
    Default Auto Z probe work in mach3 setup problems
    Hi
    Just finished installing an Mkx-IV BOB on my LXM0609 router.
    how do I make Auto Z probe work in mach3?. I can see in diagnostics it pull digitize pin when probe touch spindle. but if I click auto tool zero I get status "Not Yet Implemented"
    and if I try using "automated setup of input" in ports and pins. I just get error "only works with parallel port lpt"
    cannot find anything on youtube eg.
    BR
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Auto Z probe work in mach3 setup problems
    If you see the "Digitize" signal changing on the diagnostics page, then you have your ports and pins configured correctly. Now you just need a script that does the probing.
    Here is the script I use that zeroes the tool on top of the part. Go to Operator - Edit Button Script to assign the script to a button.
    Code:
    Dim Ztemp, SpeedCoarse, SpeedFine, SpeedRetract, MoveCoarse, MoveFine, RetractCoarse, RetractFine,TouchPlateHeight
    SpeedCoarse=100
    SpeedFine=10
    SpeedRetract=300
    MoveCoarse=-10
    MoveFine=-0.8
    RetractCoarse=0.2
    RetractFine=5
    TouchPlateHeight=0
    If IsSuchSignal (22) Then
    	Ztemp=GetOEMDRO(180)+MoveCoarse
    	code "G31 Z" & Ztemp & " F" & SpeedCoarse
    	While IsMoving()
    	Wend
    	Ztemp=GetOEMDRO(180)+RetractCoarse
    	code "G00 Z" & Ztemp & " F" & SpeedRetract
    	Ztemp=GetOEMDRO(180)+MoveFine
    	code "G31 Z" & Ztemp & " F" & SpeedFine
    	While IsMoving()
    	Wend
    	Call SetDRO(2,TouchPlateHeight)
    	Ztemp=RetractFine
    End If
    The variable names in the script are pretty self-explanatory, you can change speeds and probing distances as you like.
    If you are using a touch plate (for nonconductive materials), assign the touch plate thickness to the TouchPlateHeight variable.
    Oct 2017
    Denmark
    works like a charm thanks a lot
    I set TouchPlateHeight to 10mm
    tog
    it took me a while to find out that RetractFine has to be higher that TouchPlateHeight
    Nov 2012
    I guess line 29 should be changed to "Ztemp=RetractFine+TouchPlateHeight" to avoid that problem. I use a 1mm touch plate (just a brass washer really) so I never noticed. Thanks for the bug report!
