Need Help! Db25 1205 bob
Results 1 to 7 of 7
Thread: Db25 1205 bob
    Jul 2013
    Default Db25 1205 bob
    Hi, yesterday I'm trying the electronics. All work successful. All axis work fine. But today not. If I start the computer the let witch indicate the power on is turn on. That's mean the board drain power from lpt and not from external power supply 5volts witch is still off. The led is light little bit lower as with the eternal power on. And the big problem is that, the motors don't move.. I don't know where is the problem.. Broken lpt port, or breakout board.. Please help. Brandon
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: Db25 1205 bob
    Hi Brandon
    do you have a link to the manual for the 1205 BOB ?
    do you have a multi meter ?
    I only found a photo of the BOB
    Db25 1205 bob-1205-bob-jpg
    I assuming the two 16 pin IC's will be 74HC14 inverters
    with no power to the board and a logic 1 (+5V) on any of the printer port outputs
    the BOB will work to some degree
    current will flow via the IC's input protection diodes to the positive supply pin 16
    and power the other IC and the LED indicator at a reduced voltage
    note - if all printer port pins are at a logic 0 (0V) the board will stop working
    Db25 1205 bob-cmos-protection-jpg
    check you have power to both power supply inputs for the pc interface and output side of the BOB
    a photo or diagram showing how you have connected the board will help
    John
    PS
    high resolution photos of both sides of the breakout board will make it possible to trace the circuit
    and then work out how to test it` in more detail
    *Registered User* Johan1007's Avatar
    Sep 2018
    Hi
    I have a problem where I do not see any pulses coming through on pin2, which is my step pulse, but I do see the direction pulse changing. If I check the parallel port of the computer I do get the correct signals. Please advise.
    Mar 2007
    uk
    since my reply in post 2
    I have traced this circuit for the BOB
    Db25 1205 bob-ebay-opto-isolated-cnc-bob-jpg
    with the PDF data for the 74HC14 IC
    74HC_HCT14.pdf
    you should be able to follow the step signal from the printerport pin
    to the input pin of one of the 74HC14 IC pins
    and then from the corresponding output pin to the opto isolator
    John
    Sep 2018
    Hi John
    I have downloaded port monitor app and can control the pins through that. If I switch pins on and off, I do get that coming through. It is only when I run mach3 that I do not get my step pulse. I do get my direction pulse. Any advise on that.
    Feb 2008
    Quote Originally Posted by Johan1007 View Post
    Hi John
    Its possible your step pulses are too short to be passed through the very slow OPTO couplers on the board.
    you could try doubling your step time until it works to get an idea of how slow...
  7. #7
    Sep 2018
    Quote Originally Posted by PCW_MESA View Post
    On further investigation, we found that the opto couplers is switching to slow, the data sheet specifying a rising time of 18µsec. The max we could managed to set it in Mach3 is 15µsec. At the end of the day it is just a bad quality board.
    Have decided to go for something better.
Db25 1205 bob
Db25 1205 bob
