Need Help! ALARM 751 Spinlde 1 alarm detect (AL-31)
Results 1 to 6 of 6
Thread: ALARM 751 Spinlde 1 alarm detect (AL-31)
    Default ALARM 751 Spinlde 1 alarm detect (AL-31)
    Default GILDEMEISTER CTX 400 x 18T Fanuc Control SPINDLE PARAMETERS
    Have a Gildemeister CTX 400F machine x 2 axis and lost all the parameters in the machine. I managed to put them all in, however the spindle turns and stops immediately.
    I am getting Alarm 751 and Al 31 on the drive. I have a wrong parameter the spindle 1.... maybe the machine got a multi-spindle configuration....
    I need the spindle parameters or if anybody has a similar machine and could give me a copy I would be most obliged. I do not think that this is not a keep relay parameter issue.
    Oct 2009
    Mexico
    Default Re: ALARM 751 Spinlde 1 alarm detect (AL-31)
    Quote Originally Posted by sputnikprec View Post
    What kind of spindle unit do you have. Do you have the FANUC part number?
    regards
    Alex Fanuc
    The machine motor is Fanuc 30P spindle motor A06B-0730-B200#3000
    The drive is a spindle servo unit A06B-6064-H318#H550 and there is a label A06B-6064-C322
    many thanks for your reply.
    I would like to tell you that it is fixed. The spindle parameters I had were incorrect.
    Hi ALexFanuc,
    the machine is fixed. I got new parameters from Fanuc UK for the control and spindle and it is now sorted. I thank you just the same because you have tried as well. Thank You!
    Oct 2009
    Mexico
    Great! Thanx for your reply!
