Need Help! MAHO MH600W CLEAR PARAMETER
Results 1 to 3 of 3
Thread: MAHO MH600W CLEAR PARAMETER
    Default MAHO MH600W CLEAR PARAMETER
    I need help, I have a Deckel Maho MH600W with Heidenhain TNC 425. The buffer buttery died and clear all machine parameters.
    Can e
    Attached Thumbnails Attached Thumbnails MAHO MH600W CLEAR PARAMETER-img_20210224_102924-jpg   MAHO MH600W CLEAR PARAMETER-img_20210216_172504-jpg   MAHO MH600W CLEAR PARAMETER-img_20210216_172511-jpg   MAHO MH600W CLEAR PARAMETER-img_20210216_172529-jpg
    Quote Originally Posted by Vladede View Post
    Can e
    I found machine parameters. If anyone else is looking for machine parameters let me know.
    Default Re: MAHO MH600W CLEAR PARAMETER
    Hello, I hope you are having a good day. I had the same problem as you, all the parameters were deleted because the buffer batteries were discharged. I entered the parameters manually by entering the 95148 code, but it gives the error "red mp not correct" and the workbench keeps failing. Probably general parameters, nc parameters, cnc parameters were also lost. Can I get the files with the parameters (I don't know which ones) with TNCRemo from you? Or a backup file.
