Maho MH800C 5axis Philips 532 - B02 alarm (measuring system alarm)
Results 1 to 4 of 4
Thread: Maho MH800C 5axis Philips 532 - B02 alarm (measuring system alarm)
    Default Maho MH800C 5axis Philips 532 - B02 alarm (measuring system alarm)
    Hello All,
    Our company bought this used machine around 2 months ago and we didn't power it up since last week.
    Machine parameters are still there. I tried to bring the axes to RP, x,y,z were ok but axis B (turning rotary table around y axis) wont move at all. neither manual nor with RP command. If you try, the hydrolic will power off.
    When i try to RP axis A (rotary table), the table wont stop moving!
    Any suggestion?
    b.t.w with the machine we got a 3axis vertical postprocessor. What should we do for a 5axis processor? should we buy it from DMG MORI? or it can be downloaded?
    Thanks alot,
    Afshin
    Default Re: Maho MH800C 5axis Philips 532 - B02 alarm (measuring system alarm)
    Now this error (B02) comes at the beginning and wont let the hydrolic to stay on.
    Nov 2015
    [QUOTE = afshin1978; 2389714] Ova pogreška (B02) dolazi na po?etku i ne?e dopustiti da hidrolik ostane. [/ QUOTE]
    Attached Files Attached Files
    Quote Originally Posted by afshin1978 View Post
    Hello All,
    Any suggestion?
    Thanks alot,
    Afshin
    B axis encoder was damaged (not sure about the cause). Encoder out, B axis read out, and now it works with a vertical 3axis postprocessor.
    Now I wonder if anyone has a 5axis postprocessor or a 3axis horizontal?
    Best regards,
    Afshin
    Attached Thumbnails Attached Thumbnails Maho MH800C 5axis Philips 532 - B02 alarm (measuring system alarm)-whatsapp-image-2020-09-05-2-37-a   Maho MH800C 5axis Philips 532 - B02 alarm (measuring system alarm)-whatsapp-image-2020-09-05-2-38-a
