hello, i have a machine equiped with a indramat kda
now i have 2 replacements for this but im not sure if they wil fit,
the original drive (for maho cnc milling machine) is:
KDA-3.2-150-3-AOS-W1
The 2 spares i have are:
KDA-3.3-150-3-A00-W1
and
KDA-.32-150-3-A00-W1
so they schould be the same to use, because the only difference i have is the AOO and AOS but is
S here stands for serial interface RS232 but this one is not used on the original machine so thats nog a problem,
and i could instal the optional card if neccesairy on the AOO i suppose,
but what i seen is that the power main pcb board original is a TTS3 and the 2 replacements are TTS18
whats the difference?
they both should can handle 150Amp and 300V dv bus voltage?
