This is a very general error message
Error description 2923
Error message: C3B0 Motor ? does not rotate
Cause of error
- Inverter not ready
- Disturbance on RDY input of the PWM output connector
- Motor locked
- Motor defective
- Motor cable defective
- Humidity has entered the motor
- Inverter defective
- Incorrect motor selected (MP2200.x).
- Assignment of PWM outputs incorrectly entered in MP120.x
- Assignment of encoder inputs incorrectly entered in MP112.x
- Motor power cables mismatched
- Motor encoder cables mismatched
- Motor connection faulty
Corrective action
- Inform your service agency
- Check the inverter
- Check the motor and cabling
- Check the machine parameters
OR
Error description 8103
Cause of error
- Motor jammed
- Motor defective
- PWM output incorrectly assigned
- Speed encoder incorrectly assigned
- Motor power cables crossed
- Motor encoder cables crossed
- Defective motor connection
- I2t monitor has responded
Corrective action
- Check the motor for proper selection
- Check the PWM-output parameters (MP 803, MP 1103)
- Check rotary encoder input parameters (MP 803, MP 1103)
- Check the I2t monitoring (MP 803/827, MP 1103/1113)
