Are you sure that is not off by 0.10mm, which would cause the 0.2
error.
Changing the parameter by 0.2 would put the error on the other aide of centre.
HI,
I have a problem on my DMU 60P Deckel Maho mill, I have install a new X Axis motor and X Axis linear measuring scale.
But my X measuring system in the MillPlus is now off by 0,2 mm fram the machine cordinal.
I have been told that I can adjust the machine parameter 3125 "zero point setting"
but if I change the value in this paremeter that makes no difference.
To check I use a dial indicator in the center off the round table, and then du G53 and turn the round table 180 dec.
I measure the new value on the dial indicator and is off 0,2 mm
Can someone help me ?
\F45CNC
error.
