Error M01 in CNC 432 in MH500C
Results 1 to 5 of 5
Thread: Error M01 in CNC 432 in MH500C
    Mar 2008
    Peru
    Default Error M01 in CNC 432 in MH500C
    Hi good day i am checking cnc mill MH500C with control CNC 432, i obtain the errors M01 and I01,
    If 19RSS1 = 0 , error M01 appears (checksum fault MC memory RAM)
    if 19RSS1 = 1 , screen constant appears direct, and error I01 show it (Interface has no voltage supply).
    the battery has 12.5v, and pcb CentProdMod was changed (same model of pcb for different memorys series), before a chess screen appeared.
    I intend change the constant but no change, Are these some suggestions?,
    should i change the battery, o how change the parameters?
    regards
    Renato Masias
    Attached Thumbnails Attached Thumbnails Error M01 in CNC 432 in MH500C-016_38-jpg   Error M01 in CNC 432 in MH500C-016_39-jpg
    Mar 2008
    Peru
    Default Re: Error M01 in CNC 432 in MH500C
    I could solve this problem, replace the batery of 6v, i put all the constant, then this almost work.
    in test obtain alarm of Drive mod3, Input Module1, CentPro. , this look like electronics error card.
    Renato
    Mar 2009
    Hungary
    dear friend,
    I have M01 problem too ...at MH500C after accu change….HOW DID YOU SOLVE THE PROBLEM ???
    Can you tell me
    Janos
    Mar 2008
    Peru
    Replace the CENT_PROCMOD put parameters again and this started working.
    Mar 2009
    Hungary
    Quote Originally Posted by Renatox_ View Post
    Yes, I tryed...It is Ok!!
    Best Regards
    Janos
