It work in iso, but in certain format only.What controller? In tnc 430 N10 G200 Q200=2 Q201=-20 Q206=150 Q202=5
Q210=0 Q203=+0 Q204=50 Q211=0 * You need to fill all the drilling parameters in the exact same sequence, even if the value is zero. I wasted a lot of time with G83, working very similar (sequence matters, and all parameters must be filled). Hdh drill cycles in iso really sucks. I ended up with CAM software emulated drill cycles, and it works surprisingly well
