Need Help! MAHO GRAZIANO MT 600 C parameters lost
Results 1 to 14 of 14
Thread: MAHO GRAZIANO MT 600 C parameters lost
    Member Margean's Avatar
    Feb 2010
    Romania
    Default MAHO GRAZIANO MT 600 C parameters lost
    Hello guys
    Can someone please help me with the parameters for one MAHO GRAZIANO MT 600 C, the machine has not operated for 4 years and has lost all parameters.
    CNC: Philips 532 T / 8 ; Turret SAUTER
    Thank you very much!
    Feb 2010
    Romania
    Default Re: MAHO GRAZIANO MT 600 C parameters lost
    Come on guys, no one !?
    rahbar's Avatar
    Jan 2016
    mashhad
    Hi my friend, I have a macho graziano lathing machine mt500c with philips 532 control , 12tools ,sister target ,hailstorm pinol, 2linnut, but I have same problem and need to help .
    Feb 2010
    Romania
    Hello, you have the parameters below, but you have to keep in mind that the MT600C has larger axle sizes.
    Attached Files Attached Files
    rahbar's Avatar
    Jan 2016
    mashhad
    Quote Originally Posted by Margean View Post
    Thanks, my mt500c has sutter turret ,pinol, 2 linnut,
    Can you send me error list(error E)?
    Feb 2010
    Romania
    At the and of the PDF you have the list of general error, I will try to find for you specific list of errors.
  7. #7
    rahbar's Avatar
    Jan 2016
    mashhad
    Thanks Margean.
    I change parameter with your parameter and machine on and error E101 deleted. But New error E15 (turret incorrect position) occurred,
  8. #8
    Feb 2010
    Romania
    Just ask a tool in MDI , the turret does not know in what position it is.
  9. #9
    rahbar's Avatar
    Jan 2016
    mashhad
    Thanks for your help margean,
    E15 error caused to stop axies and after that E01 em.stop math in. I gusse to need change parameters of turret .
  10. #10
    Feb 2010
    Romania
    Check if the machine wants the turret to be done with the closed doors, check if you have all the doors closed from electrical panel, side, hydraulic, etc ...
    Turret parameters are almost the same for these machines.
    Check the number of bits going on the encoder turret , could be 4 bits or 5 bits, mine has 4.
  11. #11
    Hi, i have a machine cnc 532t and i can not introduce the parameters, can you help me? The task of editing is not avaible.thank you!
  12. #12
    Member anil39's Avatar
    Jun 2020
    Hello sir, i am having an error on my maho 600 e cnc 532 iy says E117 "tool changer not enabled" how can i solve this can you please help me?
    Thanks a lot.
  13. #13
    Feb 2010
    Romania
    Hello
    This alarm was generated after entering the parameters, or during operation?
  14. #14
    Member Krashh's Avatar
    Oct 2020
    Hello . I have maho graziano mt 500c but all documentation was lost (prewisour owner lost it ) can you help me with electrical part? mahine was modified and i need to throw all this modification away to correct working . My mahine has an hydrolic door opening mehanism and no tail stok.
