What kind of controller do you have?
Grundig, Dialog, Contour? I might be able to help you.
E-mail me: roketa@sympatico.ca
have someone from you Deckel FP4NC? i"m looking for the manual book from it.
Or anyone know where i can get it? from internet maybe? or do i have to buy it? where? how much will it cost?
thanks in advance.
Johan Stephanus
- Takisawa TC-2 CNC lathe, need manual book, electric book, fanuc manual
- Need Help!- Deckel FP4NC
- Need Help!- DC Drives on DECKEL FP4Nc
- Need Help!- Deckel FP4NC with Dialog4
We have some manual about FP4AT maybe can work in your machine. (Sorry for my English)
Roberto
Santiago-Chile
I have the manuals for dialogue 4 machine what exactly are you after mail me at monty@pnc.com.au
Anyone who could help me about finding Deckel Dialog4 Operation and service manuals?
Hi
I have all the manuals for deckel fp42nc what exactly do you need and what problems are you having
Actually i have ovehalled this machine regarding to failure of 4th axis after this i found that when you try to move the 4th axis the controller stop after random rotation and then failure sign9(the circuit open sign) apears at the left side of each axis in display and stop working!!
as for your information my job is cnc retrofit and overhall,but i lost my deckel manuals for dialog 4 and this machine have not any more.
thank u for your cooperation
regards,
Hello , Im looking for operator and electric manual of deckel FP4NC machine, Do you know where can i buy it ??
or download it??
I just have the parts manual...
I will aprecciate your help,
Regards,...
Dear Sir,
How r u?
I have one CNC machine. Complete detail with model is given below:
Machine Model: 64V Linear.
Machine Maker: Deckel Maho
Machine controller: Heidenhein iTNC530
In this machine I m facing one problem of I leak Led at power supply UV 123. That problem solved and now I have new alarm on the machine.
When I ON the machine and after complete CNC system booting. Machine gave “relay ext. dc voltage missing”.
When I ON the drives the all drives gave READY green LED. But after few seconds all drives off and machine at LCD screen gave alarm of
C3B0 Motor X does not rotate or some times it’s gave C380 Motor X not controllable.
Please give me the technical guidance to resolve my problem. Drive model is UM113.
I have no any manual and electrical drawing.
Hope you give me positive response.
My email id is Subhani_engr1@yahoo.com
Hello Guys,
I have manuals for most Deckels and controls.
Some in PDF format.
You can contact me with a PM or direct sentnermts at gmail.com.
Regards
DD
Hi, Im looking for operator and electric manual of deckel FP4NC machine
Can you help me?/
download it??
gem4@hotmail.fr
download it??
gem4@hotmail.fr
Dear All
hi
I replaced a damage bosh servo drive on Z axis Deckel FP4cc with dialog11 control cnc , but I can't setting new servomotor drive . I must adjust offset or following error but I don't have any manual for Dialog 11 and Bosch ac motor Drive .
Thanks if you help me
I need manuals for dialog11 control and bosh ac motor drive .
Thanks for your cooperations.
Best Regards
Farzad Rezaei Monfared
Email : rezaeimonfared@yahoo.com
Hi ,
I have located a Deckel FP4NC , with Dailog 4 control, the m/c is lying in w/h , can't be inspected under power, bcoz m/c requires 380v supply, while here is 415v , he doesn't have a stepdown transformer.
In the worst case , considering the old control , i am not very sure it will work properly , neither it will be possible for me to get a proper support in India , getting a support from overseas is a expensive matter , which the m/c doesn't justifies.
my question is " If control has some problem , can I run the m/c full manually, bypassing the control ?
Atul
HI SIR
CAN YOU TELL ME IF I CAN USE BT40 TOOLHOLDERS ON MY DECKEL FP4A AS IT USES ISO40 WITH HYDROLIC CLAMPING ?
CAN I GET A ADAPTER TO SCREW INTO THE BACK TO FIT MY HYDROLIC CLAMP OR EVEN MAKE ONE IF POSSABLE ?
HELP ANYONE THAT KNOWS PLEASE.
REGARDS
TERMINATOR
HI SIR
I HAVE A DECKEL FP4A AND YOU HELPED ME IN THE PAST WITH VALUBLE INFO ON THE RS 232 INTERFACE ON MY CONTOUR 2 CONTROL.
I HAVE SORTED ALL AND JUST LOVE THE MACHINE. SUCH QUALITY MACHINES IF YOU TAKE GOOD CARE OF THEM.
I WOULD NOW LIKE TO DO A 4TH AXES INTERFACE AND NEED MORE INFO.
I WAS LUCKY TO BUY A GOLDEN SUN ROTARY TABLE WITH A MITSUBISHI HA80NT E30 SERVO MOTOR.
IT IS 3 PHASE AC SERVO.
CAN YOU TELL ME WERE TO LOOK FOR THE 4TH AXES CARD TO SEE IF MY MACHINE HAS ONE INSTALLED.
THERE IS NO SERVO AMP FOR 4TH AXES IN MY MACHINE I BELIEVE.
WHAT SIGNALS DOES THE CONTOUR 2 CONTROL OUTPUT TO THE AMP?
I KNOW IT IS A LONG WAY OF FOR ME BUT I NEED TO START SOME WERE.
REGARDS
DANIEL
I have deckel fp4nc and can't run it. Have you still this service manuals?
My problem is that i have error 2302 emergency stop. All e-stops are ok. I checked whole circuit of e-stops and only relay in the computer no work. If i bridge this relay manually i can run steering all servos are green but computer still see emergency stop and i can't move any servo.
Thx for all
Best regards,
Dariusz
