Need help : DMU 80T millplus control
Results 1 to 11 of 11
Thread: Need help : DMU 80T millplus control
    Oct 2009
    Denmark
    Default Need help : DMU 80T millplus control
    Hi Cnc`ers..
    i have i problem whit a DMU 80T millplus control, i need helt whit parameter i need to change to load programs bigger then 9500 lines..
    anyone out there that can help ?
    Best Regards
    ThaDude
    Mar 2007
    Default Re: Need help : DMU 80T millplus control
    Look at your machine constants there is a constant that allows line #'s > 9500. I'm at home and don't have a list to check.
    Oct 2009
    Denmark
    Quote Originally Posted by cncmm View Post
    Great cncmm... i give it a try...
    if you find the Parameter/constants, please reply...
    because i badly need to run a 450000+ lines program...
    Mar 2007
    It's constant 773 DIO: block numbers > 9000 (0=off,1=on) .......Check it, probably a 0 now change it to a 1. Our Millplus is version 410 and constant 773 is 1
    GOOD LUCK.
    Oct 2009
    Denmark
    GOOD LUCK.
    Thank you very very much cncmm..
    Aug 2007
    PAKISTAN
    sir what is the value of machine constant of 311 and 313 ..this is use for data transmition thru Ethernet connection...with the help of tncremo...i want to connect my machine with pc..machine dmu80t with millplus grundig controller
    regards
    asif
  7. #7
    Mar 2007
    Quote Originally Posted by fsa View Post
    regards
    asif
    311=C0
    313=C100
    I am not using DNC PLus to load programs. I use CDSlite
  8. #8
    Aug 2007
    PAKISTAN
    311=C0
    313=C100
    Can cdslite manage files upload or down load from machine.
    ..i want to use tncremo ...do u know about its configuration.. right now my machine connect to my pc ..which i test thru ping 192.168.0.57 -t. From my pc and receiving signals..but not connecting to tncremo..
    Regards
    Asif
  9. #9
    Mar 2007
    I spent 20 hours trying get DNC Plus to communicate with my network and I was VERY VERY unsuccessful !
    We use cdslite and it works great. you can upload or download.
  10. #10
    Aug 2007
    PAKISTAN
    Having this alarm continues.X15+ DMC system error 2.. during program running...what happened need advice
    regards
    asif
  11. #11
    Aug 2007
    PAKISTAN
    Please see jpeg ..same problem i am facing not able to rum more then 9000 block...even my manchin constant 773 value already 1...
    Attached Thumbnails Attached Thumbnails Need help : DMU 80T millplus control-img_20181211_182511013-jpg
  12. #12
    Apr 2014
    India
    hello
    i have dmu80t with itnc 530 deckel maho machine i need electrical wiring diagram
    can anyone help me asap
  13. #13
    Apr 2014
    India
    HELLO
    I HAVE DMU80T WITH ITNC 530 DECKEL MAHO MACHINE I NEED ELECTRICAL WIRING DIAGRAM
    CAN ANYONE HELP ME ASAP.
    Best Regards
    ThaDude[/QUOTE]
  14. #14
    Apr 2014
    India
    HELLO
    email sehmbi2000@gmail.com
    Best Regards
    ThaDude[/QUOTE]
  15. #15
    Apr 2014
    India
    HELLO
  16. #16
    Apr 2014
    India
    hello dear
    i have a same machine dmu 80t itnc530
    i need electrical wiring diagram please help me
  17. #17
    Apr 2014
    India
    hello dear
    i have a dmu 80t itnc530
    machine i need electrical wiring diagram please help me
  18. #18
    Apr 2014
    India
    hello dear
    i have a dmu 80t itnc 530
