Need Help! Deckel Maho dmu50v with mill plus
Results 1 to 4 of 4
Thread: Deckel Maho dmu50v with mill plus
    Feb 2007
    Default Deckel Maho dmu50v with mill plus
    Hope anyone can help me out. We got a DMU50V in an auction and finally got it powered up the other day and I get a few errors. E01 whch is interface missing and i can clear it then when I hit the on button I get E15. Which in the book says input spindle/feed halt is low. Any ideas? the only thing the machine will do is engage the draw bar. I cannot get any of the Axis to energize and move and the spindle will not turn. I got all the manual except electrical and service.
    senthil1783's Avatar
    Feb 2020
    Default Re: Deckel Maho dmu50v with mill plus
    Hii Friend,
    I am having DMU50V millplus model.
    My machine hard disk got crashed.
    I need hard disk backup of your machine.
    Can you please help.
    regards
    senthil kumar
    India
    Hi Travis did you solve your issue with "E15 input spindle/feed halt is low"? I got the same error((
    Solved, the problem was in the spindle cooling system, so the spindle overheated and this error message appears.
    Nik86's Avatar
    Jan 2023
    i see you have machine deckel maho dm 50. I bought machine . I need help ? How to call renishava to measure tools?
    Many thanks
    SRG_1's Avatar
    Feb 2023
    Hello
    Does anyone have a BIOS photo of a 1996 DMU 50V working machine, Philips PG1220 Series, Grundig Millplus control, 5 axes. Interested settings:
    1. Submenu "Memory Shadow"
    2. BIOS Embedded Extension Configuration BIOS Extension Base Address
    3. EXM menu
    My e-mail: se_fi@list.ru
    Thank you very much.
