Need Help! PHILIPS 432 WORK WITH DNC??
Results 1 to 7 of 7
Thread: PHILIPS 432 WORK WITH DNC??
    Oct 2008
    ITALY
    Default PHILIPS 432 WORK WITH DNC??
    Hi, I have to made a motorcycle part with a very large program.
    Tha manual tell about the BTR mode to run large program but I have never tried this method.
    Can anyone help me about this??
    It is easy?
    Many thanks
    Oct 2008
    ITALY
    Default RIGHT....
    Hi, I try the BTR method and It works fine.... but I have another little problem NOW....
    The DNC software (I test sameone) transfer the file right but It can't stop the transfer and I (since today) relaunched the transfer so that to force the closing of the file (otherwise they miss some lines of program)
    I think that is a error in the configuration but I don't know which is...
    Is possible that I made a mistake in the program end line??
    P.S. you forgive my English
    Jan 2008
    canada
    You must place a "Control D" character at the end of the file. In Window XP there is no way that I know to make a control D character. So what you can do is save a file from the machine, then "cut and paste" the character in Notepad. Control D character looks like a small square box.
    Oct 2008
    ITALY
    thanks.... but.
    If I transfer a program from the CNC to the PC there isn't a "Control D" caracter... the file finish with
    N... M30
    in the line "empty" after the M30 line I can look a "space" caracter in my DNC program....
    Jan 2008
    canada
    Don't open the file with DNC program. Open it with Windows Notepad, you will see it
    Oct 2008
    ITALY
    many thanks....
    tomorrow I try it...
  7. #7
    Jan 2008
    canada
    You are welcome. Good luck!
