Try https://www.cnczone.com/v...a-abene-mills/. There are very experienced people there.
Note to Moderator - I hope this post does not contravene forum rules - I'm just trying to assist the OP.
Bill
Machine Supplier: Deckel
Machine Type: FP50CC
Serial Number: 2813-0234
Machine control: Dialog 11
The problem is as follow:
When the system starts, the sequence of starting runs normally and then it finally gives the indicated status in attachments.
Pushing green control ON button in the operator panel has no effect i.e. (drives not start), the machine then gives no error messages and no alarms as indicated in attachment "monitor1.jpg". But the abnormal behavior is that after the sequence of starting is finished:
The (READY) led in the NPC card is ON whereas the (RUN) led in this card is OFF as indicated in attachment "Dialog11.jpg"
The (CNC) led in the NSV card is OFF as indicated in attachment "Dialog11.jpg"
Please give help to fix this problem
- Problem- technical support
- Need Help!- vero technical support
- Need Help!- CMS Technical Support needed
- Technical Support Representative
- Amazing Technical Support
Bill
That was meant to be cnczone.com/vb/deckel-maho-aciera-abene-mills/ but it came out wrong.
Bill
The same problem is repeated again
