Dialog 112 tool change
Results 1 to 3 of 3
Thread: Dialog 112 tool change
    HS13's Avatar
    Feb 2009
    lipova
    Hello
    Does anybody know if it possible to deselect the tool changer of a Deckel 50V with Dialog112 controller?
    I then want to continue working with manual change.
    Many thanks in advance
    BFX20001's Avatar
    Jan 2008
    Nürnberg
    Is the machine running otherwise? Is the changer in it’s basic position?
    If yes, go to a position where you can change tools
    E.g. G0 X200 Y500
    And then M33 T1 (T= tool number)
    M33 means manual tool change, machine frees the door, you change your tool and then when you close the door again and it takes the T number.
    If you want to take the tool out manually simply write M33 T0 ; M30 in blockwrite... then T0 should be displayed
    By the way on the 112 machine one can misuse M33 to open the door after the programs’ end when you only write M33 (without T) before M30.
    Hope I was able to help you out
    Regards BFX
    HS13's Avatar
    Feb 2009
    lipova
    Thank you BFX
    I haven’t explained it very well last night. I have a problem with the drive of the tool changer- the Mitsubishi MDS- now it’s dismounted... However I wanted to continue working without a tool change. But now the machine says:
    Y03 unechiped amplifier- the controller knows that we dismounted something. I would need a hint how I can fool the controller or how to change it in the PLC so that it continues.
    Thank you very much!!
