- select Macro (contour3)
Hi
I'm have the following problem on my Deckel FP4AT with Contour3 controller:
I need to produce a cube-like component part with an annular groove on each side. Now I would like to describe this groove in a macro and call in every program for every side at a specific location.
Now to my problem:
I go to my macro list when I press %0* Then I create a macro program, e.g. % 0 * 1 and then try to select it.
Nothing happens ....
a normal program can selected. I also have the problem with a local subprogram.
Who can help me???
Greetings Adam
I have not worked for ages on this controller.
As far as I can recall it, the editing the macros is similar to the N *- sentences: Usually you need to use a key combination to switch in the program editor. Try it with FKT%.
greetings
cgTNC
- You may not post replies
- You may not edit your posts
Forum Rules
