- parameter Dialog 11
Hello everybody
When I write an edge rounding into a parameter, then the Dialog 11 always complains.
Why?
A small example:
N10 G17 TT1 M66; M3
N20 G48; G49
N30 P1 = 5
N40 G0 X-10 Y-10 Z50; M8
N50 G0 Z2
N60 G1 Z-10
N70 G41 G45 R5 X0 Y0 G1 G60 M62
N80 G1 Y50 UR P1
N90 G1 X100
N100 G40 G45 R5
When I confirm the N80 sentence then an error message comes up.
What can I do so that the error doesn’t occur?
Many thanks in advance
Hello ricoh77,
When pressing enter, the contour calculator creates fixed G1/G2 and G3 command. So it needs constant values.
As an alternative you can use modal edge rounding, if I remember correctly. However I forgot the particular G command. It should also work with parameters.
Regards
cgTNC
As far as I know you can call the modal edge rounding with G7.
Simply add a command with G7 R.. between the sets that you want to round.
I know the command from Deckel Contour 2/ Dialog 4 so I don’t know if it still exists in Dialog 11.
- You may not post replies
- You may not edit your posts
Forum Rules
