- Tooling setup Help -Doosan Lynx
I require some help in setting up a 6mm round tool ( srdcr 2020 tool holder) in a Doosan Lynx , for doing a face concave cut. Currently tried tip set at 7 and the tip offset to place it at zero in the x axis in the centre of the 6mm insert. - —> O. Cannot get it to cut the correct curve. Help if you know!
- You may not post replies
- You may not edit your posts
Forum Rules
