I would doubt it is a frequency error. The cause of OH could be incorrect function of a motor (turret index for example) I happened while moving could be the motor cable has a bad connection. Is the motor hot ? If motor and cables are ok suspect the drive transistors, remember, just because you changed a drive doesn't mean it can't be faulty.
