- DOOSAN DAEWOO PUMA 150G
I RECENTLY PICKUP A DOOSAN DAEWOO
PUMA 150G GANG TYPE LATHE EQUIPPED WITH VISION380L CONTROL , THE ISSUE IS THE CONTROL LANGUAGE IS IN KOREAN AND I WILL VERY OBLIGED TO KNOW IF THERE IS ANY POSSIBILITY TO CONVERT THE LANGUAGE FROM KOREA TO ENGLISH.
hammadqureshi000@gmail.com
Re: DOOSAN DAEWOO PUMA 150G
That is a Mitsubishi controller. Contact them for the parameter setting needed.
it's not Mitsubishi
the don't support it
- You may not post replies
- You may not edit your posts
Forum Rules
